What transformer is to use to convert from LL-GDA94 to MGA94 (i.e. Lat/Long to Projected coordinate system)?
smfks911
Hi altruist, I have a set of data MITAB data in LL-GDA94. Which transformer should I use if I want to transform it into GDA94?
Best answer by redgeographics
The Reprojector (and presumably the EsriReprojector and Proj4Reprojector as well but I haven't tried those)
Forum|alt.badge.img+50
  • August 31, 2022
smfks911
  • August 31, 2022
Thank you @Hans van der Maarel​
smfks911
  • September 1, 2022
Hi @Hans van der Maarel​ do you know why I am getting this message when using reprojector on TAB file and writing to TAB as well? I have source CRS: LL-GDA94 and destination MGA2020? Even I changed the destination CRS to LL-GDA2020, still same warning message
No projection bounds specified for output file 'xxyy.tab'. MBR of dataset will be used as bounds. Note that custom projection bounds can be specified as writer directives or in file 'exceptions/mapinfo.db' or 'MapInfoBounds.db' in the FME Reproject folder
That's not really a warning, more like information. It shouldn't terminate the translation and as long as your data is in the area where that projection is appropriate it shouldn't be a problem.
