what is the difference between group elements by Geometry and Schema numbers in properties of bentley v7
  • Jan 25, 2020 4:28 AM UTC
  • 49 views
gogopotter90
Forum|alt.badge.img+14
Hello Guys ,
i am misunderstanding this point ,i hope some one explain to me
i mean when i choose geometry i got lines feature seperately but when i do schema level names i do not have same feature type lines or another names as geometry
i have lots of numbers and when i connect with inspector ,what i got from schema numbers i could not find the same amount numbers that i knew it before from lines (Geometry)
what is important for me ,lines and polygon too find intersection but when i extract geometry , polygon collections what i got from geometry it seemly not working or misunderstand for me,bcs when i connect with inspector i see nothing so i was thinking to try something else as schema numbers
iam totally new in program but iam still trying and i hope someone guide me ,how to find intersection betwen line and polygon from dgn file .
somethinfg else i want to know,
what is linkage extraction should i mark it or not.
Thanks in advance
Forum|alt.badge.img+63
That's pretty much it: grouping by geometry gives you a feature type for each type of geometry found in the file: points, lines, polygons and so on. The other options group by level name or number.
By the sound of it, and your other recent questions, you'll probably want to group by geometry.
