What is the best workflow to maintain CAD DGN Text Size when converting to ESRI Geodatabase Annotation using FME? I am ending up with exploded text size as in the attached exploded-text.jpg after conversion.
  • Mar 14, 2018 9:24 PM UTC
  • 66 views
daveatsafe
Forum|alt.badge.img+24
  • Mar 14, 2018 10:24 PM UTC
Hi @dlight,
The annotation size form the CAD data should convert to the proper Esri annotation size. However, you can control the output text size by setting the attribute geodb_text_size to the desired value.
Would you mind sharing your workspace with us?
