Weird issue, why does this happen ? Excel, WGS84 coordinate, VertexCreator, invalid parameter Y or X
  • Sep 22, 2021 1:01 PM UTC
  • 231 views
essb
Hi
I want to know why this happens so I can correct it in the feature. I attached the example file "Excel" containing only one row so you can test for yourselfs.
In Excel both coordinates have comma.
excelWhen I use Excel Reader in FME it changes only attribute value for attribute aa to a dot. But for bb its still a comma.
fme_excelThis is maybe why I cant create a point using vertex creator, even tho I use string-replacer to change both values to dot or comma it refuses to create a point.
fme_screenshot
This happens fairly often so It would be nice to know what cause this issue and how I can solve it.
It might be a bug or something to do with Excel. If I create a new excel file and manually enter every value then it suddenly works. But this is not something I can do with an Excel containing thousands of rows.
Iam using Fme 2020.2.5.0 Build 20827 - WIN64
Best answer by danilo_fme
Hi @essb​
I used the transformer StringReplacer for replacer all attributes that has " , " change automatically for " . " .
After I used the transformer AttributeTrimmer for elimate spaces into attributes:
Workspace_String
Attached the Workspace template (.FMWT ).
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Sep 22, 2021 1:20 PM UTC
Hi @essb​
Workspace_String
Thanks in Advance,
Danilo
essb
  • Sep 22, 2021 1:33 PM UTC
Hi @essb​
Workspace_String
Thanks in Advance,
Danilo
Ah, dumb me! it was a hidden character in front of 18,01757! I actually feel embarrassed now for not even thinking about that possibility :D
Thanks alot for solving it so fast. Now I know how to handle cases like this.
Problem solved.
danilo_fme
  • Sep 22, 2021 2:22 PM UTC
Problem solved.
Thanks your reply! :)
I'm happy to help you!
