WebMapTiler transformer numbering
  • December 27, 2013
  • 70 views
Hi FME's heroes,
I've got a question about the webmaptiler transformer.
I'm trying to generate tiles for a Google Maps API map but the numbering in output does not match to what I expect. I read the doc and tested the different attributes fanout, the different schemes, but I'm still stuck...
I expect that (generated with QGIS) :
But I get only
Any idea how to do ?
Thank you from France for your help
fmelizard
Forum|alt.badge.img+22
  • December 30, 2013
Hi AymFR17
You should be able to reproduce this structure in FME with a combination of:
- the AttributeCreator which can be used to make attributes combining the various quadkey, zoom level, row and column attributes needed
- fanout feature type which will make files based on attribute values
- fanout dataset which will make directories based on attribute values
Looking at your screen shot I can't quite make out the scheme you are hoping to replicate. Can you tell me the zoom level and the approximate location in Sperical Mercator coordinates and I can likely give you more detail on how to acheive this.
Thanks
Ken
  • December 30, 2013
Thanks for your answer Ken.
Here are some more informations :
- Zoom level wanted : 19 only
- Approximate location is over Brussels in Belgium, in EPSG 3857 : X 150000, Y 170000
It looks like each folder name is the column and each PNG name is the row according to this site : http://www.maptiler.org/google-maps-coordinates-tile-bounds-projection/
Thanks
  • December 30, 2013
Nice, it works perfectly !
Thank you for your help Ken
