Warning about Dissolver (only version 10) FME2013
  • November 27, 2012
  • 0 replies
  • 41 views
sigtill
Forum|alt.badge.img+25
Just a warning to those of you using Dissolver (version 10), it is broken - so the dissolved output is "inversed" in overlapping areas. using the old Dissolver (version 8). is OK. Thats for any geometry (even simple bounding boxes).
As a side note a thing to consider at Safe might be adding an "auto-update" procedure in all versions (even BETAs). This way it would be possible for Safe to notify an individual installation at runtime and give a pop-up with for instance the following:
"There is a newer version of FME available. Critical fixes includes:
- Error in Dissolver: fixed
- Bufferer: fixed
For other improvements look at
http://downloads.safe.com/fme/whatsnew.txt
Do you want to update to this new version?
Of course you would need to only update the required modules (not a complete install) - however it would be very easy for you to publish crucial updates.
