visualize if there are more than one point in a polygon (a lot off points and polygons)
The question is:
Which areas have more than two points in it.
So I want to make a selection of points in a lot of area..
Visualize if there are more than one point in a polygon (a lot off points and polygons)
Forum|alt.badge.img+40
  • August 16, 2018
You can use a spatial relator or a point on area overlayer to count the number of points falling within a polygon
danilo_fme
Forum|alt.badge.img+50
  • August 16, 2018
Hi @jopie
I believe that you can use the transformer PointOnAreaOverlayer to generate the attribute _overlaps.
After, I uggest you to use the transformer Tester and configure this: _overlaps > 2 ( for example )
Thanks,
Danilo
