Version upgrade to 2019, getting error "
  • Nov 20, 2019 4:11 AM UTC
  • 58 views
I have several workspaces that work with Caris CSARPC Point Cloud files, I have just upgraded to v2019 64bit from 2018 32bit. I also have had an OS upgrade from win7 to win10. I know a lot of changes...
When I run the workspaces now, I get an error "The error was 'Caris error: 139764: Internal error" and "Error running translation", in 2018 I don't get this and it works fine. I can't find a reference to the Caris error number anywhere, does anyone know how to find this?
(Note: If I run in Cache mode and step through all transformers I don't get the error???, Also I'm writing all fme temporary files to a file share that has plenty of space)
general process at start of all workspaces is:
- creator
- FeatureReader (CSARPC)
- PointCloud Coercer
- CoordinateExtractor (just extracting z value)
Hi, Just ran one of the workspaces through the 32 bit FME v2019 and got the errors in debug mode: see attached text file of log file.
thanks in advance if anyone has any ideas???
Brendan
fmecsarerror32bitnone2none.txt
craniumak
Forum|alt.badge.img+4
  • Nov 20, 2019 5:35 AM UTC
Might be a dumb question, but did you create new readers and writers? Might clear up the issue.
