Validate Multiple Input Files from a tool using Python
  • February 5, 2016
  • 12 replies
  • 103 views
parashari
Hi.
I am having my most weird question here.
There are multiple folders (2000+) having similar text file in each folder and I want to validate all the folders using a tool. The output of the tool is an html file (say 'validated') which is same resulting in overlapping of the o/p file. Is that possible using FME/Python to validate all files and giving me different outputs for each.
  • February 5, 2016
You can retrieve properties of every text file in those folders with PATH reader. A Python script can also be used of course. What do you need to validate? Find same name files?
parashari
  • February 5, 2016
Hi Takashi.
There is a tool which validates the GTFS data according to certain set of specs.
  • February 5, 2016
Does GTFS mean this (Wikipedia: General Transit Feed Specification)? FME should transform every txt into html?
  • February 5, 2016
  • February 5, 2016
Ah, perhaps you need to compare the contents of "validated.html" and the text files saved in the multiple folders. Is it right? If so, you can use the HTMLToXHTMLConverter to convert the HTML doc to an XHTML doc which can be parsed as an XML doc. Then, parse the XML and compare with the text files. The concrete way would be different depending on the schemas of the html and text, but I believe that it's possible using some FME transformers.
fmelizard
Forum|alt.badge.img+22
  • February 6, 2016
Sounds like you have an external command line tool that you want to run on all these input files. I presume it is a command line tool.
As @takashi suggests, you can use the Path reader in FME to get you one 'Feature' per input file. Then you could use the SystemCaller to run your command line tool, with the right arguments, to produce its output.
It sounds like it always produces the same filename as the output file. Once you return from the SystemCaller, perhaps the next thing in your workflow could be to use another SystemCaller to Rename your files (or a TclCaller or a PythonCaller). You could use FME to help you compute a unique name for your output file based on the original input file's name, which would be available on the feature flowing through.
parashari
  • February 8, 2016
Yes. Its the same.
parashari
  • February 8, 2016
Hi. @takashi. I do not need to compare the output from each file. I need to verify which input files are good to be processed further by validating the data from that tool. And since, all the validation results give the same output, the files will be overwritten, so I need to renames all the files.
parashari
  • February 8, 2016
Hi @daleatsafe. I am not sure of using SystemCaller. Can you guide me with that.
  • February 8, 2016
How can you check if an input file has been processed correctly by the tool? If the resulting HTML document contains the information about successfully processed file paths, just retrieve the paths from the HTML and then compare them with the original file paths which can be read by the PATH reader.
parashari
  • February 9, 2016
So, for that I have to check each HTML output manually and then see which inputs have to be taken forward according to the validation results (if no errors, inputs to be processed further, else not).
  • February 9, 2016
sorry, I'm unclear your requirement. Could you please explain more clearly with some concrete examples?
