Using wildcards in Attribute Filter?:
jhawks
Forum|alt.badge.img+7
Workbench is S-57 .000 files to File GDB. I only want to write Soundings that meet that meet the criteria SORIND where it's equal to US,US,graph,Chart * (for any chart number). Is this the correct transformer, syntax etc:
daveatsafe
Forum|alt.badge.img+19
  • April 17, 2023
Hi @jhawks​,
I think you may have more success with Tester transformer, which lets you use the Contains Regex test. You can then create a Regular Expression that catches all the possibilities you want. The transformer includes a simple Regex sandbox, but you can also find a more comprehensive one at https://regexr.com/.
jhawks
  • April 18, 2023
So this?image
daveatsafe
  • April 18, 2023
jhawks wrote:
So this?image
I would recommend this (a bit simpler than RegEx):
Screen Shot 2023-04-18 at 9.29.57 AM
jhawks
  • April 18, 2023
Everything is failing. Here is a sample string from the attribute table of the GDB. US,US,graph,Chart 16646
And here are my Tester Parameters:
daveatsafe
  • April 18, 2023
My apologies, I thought that the commas separated different options instead of being part of the string. Please try the following:
Screen Shot 2023-04-18 at 11.27.36 AM
jhawks
  • April 18, 2023
That's it! Thank you very much!!
