Using the Matcher transformer, is it possible for me to produce results from matched output and choose which row of attribute to merge and keep the attribute?
  • Jul 24, 2023 5:28 PM UTC
  • 38 views
eqwansyafiq
Participant
Forum|alt.badge.img+3
Screenshot 2023-07-25 011742I attach a visual example, from the visual preview, I want the blue tick row to merge/duplicate the attribute while the row with the yellow mark to keep the attribute value from the original value.
Any help or guide will be appreciated. Thank you.
hkingsbury
Forum|alt.badge.img+73
  • Jul 26, 2023 8:11 PM UTC
The featuremerger (or featurejoiner) might be a better approach here, as that gives you control over what is the "original" value (requestor). The matcher doesn't know what feature is the "original" as it only has one input port
