Using markdown in MSWordStyler to create a link in a Word-file
  • Aug 27, 2018 11:41 AM UTC
  • 332 views
I'm trying to write a link in the Word-file, that I'm creating with MSWordStyler-transformers and the Microsoft Word writer.
I'm using markdown, but it isn't written af a link - just as plain text.
I'm writing this in the Text-field in the MSWordStyler with Content Type set to Paragraph:
[Klik her:](http://www.ph.rm.dk/Omraader/sundhedsberedskab/arrangementer-begivenheder-og-events/)
jovitaatsafe
Forum|alt.badge.img+11
Hi @ikast_mofri,
Have you tried using this syntax when creating your hyperlink in markdown?:
[Hyperlinking text](https)
To insert links, enclose the text in [square brackets](followed by the URL) - the descriptive text will show the hyperlink highlighting.
I think that article might also be helpful to refer to: Format Help in FME Hub with Markdown
Hi @ikast_mofri,
Yes, that's how I'm doing it - but it isn't shown as a hyperlink.
jovitaatsafe
@ikast_mofri, my apologies, it appears that this function isn't yet available for the MSWordStyler, as the MS Word Writer is still quite new for us (2018!). I have created an Idea for you to add the ability to create hyperlinks, and also put in an enhancement request (FMEENGINE-56440). If you could upvote the idea, that will raise its visibility for our developers, and you will be alerted when its status changes. Thanks!
- Jovita
