Using JSONTemplater for the first time and i keep getting an error message saying ':Downtown" : pair with the same name already exists in object', and not sure how to solve this.
  • Jan 13, 2023 5:24 PM UTC
  • 162 views
debbiatsafe
Forum|alt.badge.img+24
Hello @sharminn​
Usually this error means another JSON object with the same name (eg. Downtown) already exists in the output JSON. Are you able to share your workspace along with a small example of your input data?
  • Jan 20, 2023 11:08 AM UTC
Hello @debbiatsafe​
Thank you for responding, i was following the following guide from FME, https://community.safe.com/s/article/json-writing-with-jsontemplater
and below is the input data i believe in JSON, and my workbench.
imageimagethanks for responding!
debbiatsafe
Hello @debbiatsafe​
Hello @sharminn​
I tried following the instructions in the article and was able to successfully create a nested JSON file. You may have a typo in the JSONTemplater or another transformer elsewhere in the workspace is misconfigured, causing the error.
Are you able to share the workspace you currently have?
  • Jan 23, 2023 11:47 AM UTC
Hello @sharminn​
Yes you were right, i've just been through it again, and it's the sampler transformer that i hadn't got the right parameters stated. Thank you so much, it works fine now 😊
