User Parameter Choice (List) within Custom Transformer doesn't work
  • Sep 29, 2020 10:18 PM UTC
  • 69 views
matthieuv
Forum|alt.badge.img+30
I have a workspace with an User Parameter of type Choice (List). When I put this with AttributeManager into an attribute I can see that the choices I made (checkboxes I ticked) are listed. However, when I use that same Custom Parameter inside an embedded Custom Transformer it doesn't reflect anymore my choices.
Does anybody know if I'm doing something wrong or if I stumbled upon a bug?
I'm using FME 2019.2.3.1
Best answer by matthieuv
Hello @kailinatsafe​, thanks for your reply. I just took a new look at it and solved the problem. I didn't expose the parameter which used the Choice list. By doing that and addings as input the User Parameter it is now working as expected.
kailinatsafe
Forum|alt.badge.img+24
Hello @matthieuv​ , sorry to hear you are having difficulties with the transformer parameters. What custom transformer are you working with?
matthieuv
  • Oct 6, 2020 7:56 AM UTC
