Use Stringreplacer to remove data contained in brackets? e.g. "Akermaat (A9 Alkmaar - Amsterdam)"
  • Nov 1, 2016 11:04 AM UTC
  • 5 replies
  • 350 views
Hi all,
I'm trying to remove some unwanted data using StringReplacer.
I'd like to remove all data contained within brackets and also remove the brackets themselves.
What I have:
Alblasserdam (A15 Sliedrecht – Ridderkerk)
Bospoort (A4 Schiphol - Den Haag)
What I want:
Alblasserdam
Bospoort
Can I use StringReplacer for this?
Thanks,
Ed
Best answer by takashi
Hi @edttom, yes, I think the StringReplacer with this setting does the trick.
  • Text to Find: \\s*\\(.*?\\)
  • Replacement Text: <not set>
  • Use Regular Expressions: yes
  • Nov 1, 2016 11:14 AM UTC
  • Nov 1, 2016 11:33 AM UTC
Many thanks for the fast response @takashi , it worked!
However, I'm curious as to what "\\s*\\(.*?\\)" does. Can you clarify or point me to some documentation explaining this query?
Thanks
  • Nov 1, 2016 11:42 AM UTC
Thanks
The help doc on the StringSearcher and the StringRepalcer contains short description about regular expressions. Then, see also these links to learn more.
  • Nov 1, 2016 12:03 PM UTC
Thanks
Addition.
  • \\s* 0 or more whitespaces
  • \\( an opening round bracket
  • .*? 0 or more any characters (? indicates that "matches the minimum length" in this case)
  • \\) a closing round bracket
arekpierchala
Thanks
Takashi gave you most elegant solution.
It is Regular Expresion.
Watch how it works e.g. at http://rubular.com/ or directly in FME when open properties of 'Text to Match' if 'Use Regular Expression' is maked to 'yes'
