use parameter display value as attribute
  • Nov 12, 2024 3:23 PM UTC
  • 105 views
katt
Forum|alt.badge.img+12
Good day,
I have a featurewriter and I want to give the dataset the same name as the display value (and not the value itself) of a parameter for which I used a choice configuration. How can I do it ?
  • Nov 12, 2024 5:17 PM UTC
Unfortunately, you can’t retrieve the display label from the choice parameter. You could consider using an AttributeValueMapper to map the value back to the display label.
