Use of filter in Insectors Table View
  • Dec 14, 2017 4:20 PM UTC
  • 121 views
elzbieta
Forum|alt.badge.img+8
One column has 4 values 2, 12 324, 56987 (data type is number)
When I use filter in Inspector (Table View) to find records with value 2 I got 3 results (2, 12 and 324)
Earlier versions of Fme gave me just one result: 2.
Is it a method to find just records with value 2?
Thanks in advantage:)
Best answer by fmelizard
Hi @elzbietalekve which version were you using previously? I tried FME 2014 and found the same behaviour as FME 2017. I tested both filter methods @danilo_fme showed below. Here is an idea which you can vote on which is asking for what you are expecting: https://knowledge.safe.com/idea/20165/add-filter-function-to-the-table-view-in-fme-data.html (I have also voted on it as I think this would be pretty handy :-D). At this point the only workaround I can think of if using a Tester in a Workspace which is a little impractical
danilo_fme
Forum|alt.badge.img+58
  • Dec 14, 2017 5:15 PM UTC
Hi @elzbietalekve,
Try to use the option Display only the features:
You set the condition that you need:
For example:
ID1 = 2
Thanks,
Danilo
elzbieta
  • Dec 18, 2017 4:13 PM UTC
But I want that in Table view I could see just records with the value 2. When I have 50 000 records in my base and I want to find just 2 of them so I will see just 2. oadminelaantall-teigansw-danilo.pdf
fmelizard
Forum|alt.badge.img+22
  • Dec 18, 2017 5:57 PM UTC
elzbieta
  • Dec 19, 2017 9:18 AM UTC
I tried the earlier version of FME and I saw that Filter works in the same way. Then it's dawned on me that I most of the time used an unik number in my data. So I am really sorry for misleading
information to both of you (danilo_fme and MattAtSafe) . But I think that is good idea that Filter sholud work as I suggested and will vote for this kind of solution. Thanks very much for Your help:)
