UPLOAD MULTIPLE FILES TO FME SERVER PROCESS
tbs_gis_team
I created a process to rename and resize jpgs in workbench, and able to select multiple jpgs or directory to run my process, but I am not able to make the process do this when I upload to FME server.
Thanks,
Chad
tbs_gis_team
  • August 29, 2013
Nobody??
tbs_gis_team
  • September 3, 2013
I am also trying to carry over jpeg attributes to a jpeg writer.
Chad
In order to help you, a little more information about what exactly is not working when you put it on the server would help.
tbs_gis_team
  • September 5, 2013
I need to be able to have the published parameter able to select multiple files at one time. When I upload the process to server you can only select one file at a time. In workbench you can select multiple files at once. I was also wanting to see if it is possible to attach the attributes of the source jpeg (it has original data, camera make and model, etc). FME reads the attributes I attach to writer but it will not write them out.
Chad
How are you getting the files from the user to the server?
tbs_gis_team
  • September 5, 2013
They would upload them manually, as needed. It is set up as a user paramter.
CK
bo
Forum|alt.badge.img+10
  • March 4, 2017
@tbs_gis_team, I believe I am having the similar question. Did you ever find a solution?
It is possible to zip the files before uploading to FMEserver. However, that is not ideal in my situation, dynamically zipping up files in a web application is a bit problematic and time consuming...
itay
Forum|alt.badge.img+17
  • March 5, 2017
Hi, why not use the Directory watch publication protocol on a resource location or a network location? this way uploading the files is just a matter of copying them.
bo
  • March 7, 2017
Great idea, @itay! I think we can write a service for uploading file to a resource location where the directory watch publisher will trigger the workspace that transforms the data to the back-end database.
itay
  • March 8, 2017
Just be aware that the directory watcher (depending on the fme server) has done known issues and most of the times an inetrmediate filtering step is necessary.
