update script doesn't work
  • Oct 30, 2018 12:58 PM UTC
  • 13 replies
  • 98 views
I've got the following script in an SQL Executor:
update tbx.ext_compare_person
set   gesnam_d = tbx.diakriet_cip(gesnam_d,sourcekey,'Gesnam')
,     gesvor = tbx.diakriet_cip(gesvor,sourcekey,'Vornam')
,     gesnam_d_partner = tbx.diakriet_cip(gesnam_d_partner,sourcekey,'GesnamPartner')
where organisation = '1234'
and   applicationcode = 'ABC'
Parameters are:
When I execute the script via "Run" (test in SQL Statement) it runs perfectly. It updates the correct rows. But when I run the translation complete, it doesn't perform as tested (it updates nothing).
What is the best solution here? Am I doing something wrong?
Thanx in advance, Erwin
  • Oct 30, 2018 1:03 PM UTC
From the screenshot it looks like you have some comments inside the SQL statement editor. Can you try removing all the comments and see if that makes a difference?
  • Oct 30, 2018 1:06 PM UTC
Nope, doesn't make a difference.
Another thing to try would be to insert a SQLExecutor just before with the following statement and see if anything exits the Result port:
select *
from tbx.ext_compare_person
If nothing comes out the Result port, it's an indication that there's simply nothing in the database to update at that point of execution.
  • Oct 30, 2018 1:08 PM UTC
select *
As I said in my Question, the script runs fine if I perform a testrun. But when I start the translation it does nothing.
  • Oct 30, 2018 1:11 PM UTC
I know, I did read your question. But are you 100% certain that the state of your database table is identical when you test the script and during the translation?
  • Oct 30, 2018 1:12 PM UTC
For example: is it possible that you're trying to update a table entry that's in an uncommitted transaction when the SQLExecutor is triggered?
Forum|alt.badge.img+54
  • Oct 30, 2018 1:14 PM UTC
What is triggering the sql executor?
  • Oct 30, 2018 1:23 PM UTC
Nothing :-)
nielsgerrits
Forum|alt.badge.img+67
Nothing :-)
I think @egomm is correct. Maybe you just need to trigger the transformer to run it. A Creator Transformer can do this. This is the way FME workspaces are built; a feature hits a Transformer and then it starts to run.
  • Oct 30, 2018 1:56 PM UTC
I added the trigger "SQL Creator" with the following script:
select sourcekey
,      gesnam_d
,      gesvor
,      gesnam_d_partner
The given columns are selected in the Attributes to expose (SQL Creator Parameters).
If I connect the SQL Creator (result) with the SQL Executor (initiator) it runs. But very very slow. Is there a way to improve the speed of the translation?
nielsgerrits
select sourcekey
,      gesnam_d
,      gesvor
,      gesnam_d_partner
How many Features flow from the SQLCreator to the SQLExecutor? See the number on the Connection between the SQLCreator and the SQLExecutor. If there is more then one, your SQLExecutor script is run that number of times. I guess you need it to be run only once? A Sampler Transformer will let only one Feature past when set to 1 First N Features.
  • Oct 30, 2018 2:05 PM UTC
select sourcekey
,      gesnam_d
,      gesvor
,      gesnam_d_partner
Try using the regular Creator + SQLExecutor, not the SQLCreator + SQLExecutor.
  • Oct 30, 2018 2:11 PM UTC
select sourcekey
,      gesnam_d
,      gesvor
,      gesnam_d_partner
Another thing to check regarding speed is to see if the fields "organisation" and "applicationcode" have an index in the database.
