Update in gdb file is to slow
  • Jun 28, 2023 6:35 AM UTC
  • 78 views
Hello,
I created a script that update a gdb file. The problem is that in a table it update all fields in 10 minutes. In a other table in same database with same quantity of data it update in 3 days . What is the problem ?
Do you have any idea or documentation about the gdb/sde update parameters?
a capture to the table problem .
ELE_MUFFE work perfectly but no ELE_MUFFE
FME problem
nielsgerrits
Forum|alt.badge.img+67
Do you use the exact same strategy for both tables? Or edit session for one, transactions for the other? Because if FeatureOperation is based on fme_db_operation, I think it will do row by row, as edit sessions, not as transactions, which does blocks of 1000 features.
  • Jun 28, 2023 10:53 AM UTC
muffe slow and no slowI send you the parameters to the update .
Wenn I try to use to the table WP_MUFFE Match Column they dosen't work .
