Unable to add Root Template on XMLTemplater
  • Feb 20, 2017 4:06 PM UTC
  • 33 views
I'm unable to add a Root Template on the XMLTemplater Parameters window as displayed on screenshot below. Collapsing Sub Template or resizing window does not resolve the issue.
Versions:
FME Desktop 2017 RC (installed package: fme-desktop-2017_2017.0.0.0.17245-ubuntu.14.04_amd64.deb)
OS: Ubuntu 14.04
  • Feb 20, 2017 4:36 PM UTC
Looks like a GUI bug, you should consider submitting it to Safe support: http://www.safe.com/support/
You could also try different dpi settings (or themes or fonts) on your display settings and see if it makes a difference.
