UDP Traffic to port 1434 blocked
  • Aug 24, 2018 5:56 AM UTC
  • 313 views
Anyone able to help me with this?
com.microsoft.sqlserver.jdbc.SQLServerException: The connection to the host DEV-TFS, named instance TRAVEL failed. Error: "java.net.UnknownHostException: DEV-DB". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.
Working on FME Desktop but when I published the workspace to FME cloud this error comes up. I believe I already enabled inbound UDP traffic to pass through on port 1434 shown below.
Any idea what else am I missing?
Thanks in advance.
itsmatt
Forum|alt.badge.img+48
  • Aug 24, 2018 10:35 AM UTC
When you say FME Cloud do you mean Safe's hosted version? Or are you running your own install of FME Server on your own virtual machine? From the screen shot it looks like you have your own VM? Can you confirm?
