Tweeter 403 Forbidden from https://api.twitter.com/oauth/access_token
  • Jul 11, 2017 1:11 PM UTC
  • 22 replies
  • 177 views
I had various tweeting workspaces working fine (for about a year) up until about 5 days ago and now I get the routines failing to send the tweets showing the Error in the log:
2017-07-11 14:02:01| 8.3| 0.0|INFORM|HTTP/FTP Transfer: Downloading resource 'https://api.twitter.com/oauth/access_token' to internal memory buffer
2017-07-11 14:02:01| 8.3| 0.0|INFORM|HTTP transfer summary - status code: 403, download size: '130 bytes', DNS lookup time: '0 seconds', total transfer time: '0.296 seconds', url: 'https://api.twitter.com/oauth/access_token'
2017-07-11 14:02:01| 8.3| 0.0|ERROR |Received HTTP response header: 'HTTP/1.1 403 Forbidden' from 'https://api.twitter.com/oauth/access_token'
When I click on the Twitter link I get the following response from Twitter in Chrome:
Invalid request token.
I can still log into the Twitter account manually through Chrome and send Tweets.
Thanks in advance.
Running FME Workbench Build 17291 (2017.0.1.1)
Best answer by themingster
Looks like it'll be fixed in the next release :-)
"Tweeter_Tweeter(TwitterFactory): Due to a change in the Twitter API, all Twitter transformers are non-functional. Updated transformers will be released with FME 2017.1.1"
danilo_fme
Forum|alt.badge.img+58
  • Jul 11, 2017 1:24 PM UTC
Hi @themingster,
Do you use the transformer Tweeter or TweetSearch?
Thanks
Hi @danilo_inovacao, it's the "Tweeter" transformer I'm using to post a tweet and I follow that account to pick up the notifications.
By the way I'm quite the novice at FME.
danilo_fme
  • Jul 11, 2017 1:56 PM UTC
Hi @themingster, i tested here in my PC and has this error too. I believe the policies authorization of tweet was changed, so the reason the error is show in transformer.
Thanks,
danilo_fme
  • Jul 11, 2017 2:53 PM UTC
@themingster
I installed the FME Desktop 2017 1.0.0 ( Build 17523 - Beta ) and tested the transformer but without success. The same error was show in the Log file :(.
I checked that the url to send request in twitter actually is: https://dev.twitter.com/oauth and not https://api.twitter.com/oauth/access_token that is generate by transformer TweetSearch.
I believe the reason the error is the URL.
Thanks in Advance,
Danilo de Lima
I am also facing the similar issue with the "TweetSearcher" transformer since a couple of days. Before that, it was working absolutely fine.
https://knowledge.safe.com/questions/47672/tweetsearcher-authentication-issue.html
mark2atsafe
Forum|alt.badge.img+59
My guess is that Twitter have changed something. I've flagged it as a high-priority issue with our developers and will get back to you.
Mark, thanks very much.
I thought I had broken something or that it was a firewall issue.
Will wait your reply.
Adrian
As a temporary workaround, you may be able to use the Twitter API through a HTTPCaller.
In this question I mention how to I have spoken about how to authenticate with it, and then use the general Twitter search tool. I'm not sure what the limitations are from the authentication method. https://knowledge.safe.com/questions/45854/httpcaller-and-twitter-api-authentication-problems.html
  • Aug 3, 2017 10:23 AM UTC
mygis
Forum|alt.badge.img+14
  • Sep 11, 2017 12:20 AM UTC
Hi @Mark2AtSafe,would you be able to let us know as soon as it is available even in a beta release of 2017.1.1? Thanks.
mark2atsafe
Will do @gisinnovationsb - it should be very soon now. I'm hoping for a beta fix by the end of the week. We're aware it's a priority issue for users and we're doing all we can do get it fixed asap.
mygis
  • Sep 11, 2017 1:02 AM UTC
Thanks @Mark2AtSafe, and also to all the developers working on this as it is not easy to keep track on the API changes made by third party products.
  • Sep 15, 2017 10:58 AM UTC
Thanks Mark,
One use of the Tweeter is to let me know when the server storage is below a certain threshold and I can therefore take action. This is because the IT company we employ has a habit of phoning us when the storage gets low, then they send us a bill for the pleasure!
Got a phone call from them last night :-( £££££££
mark2atsafe
Thanks Mark,
@themingster @gisinnovationsb Have a try with the latest 2017.1.1 beta. I believe the fix should be in there for Desktop. You may have to create a specific web connection, and I don't think Server is ready yet because the interface isn't updated to handle those yet. I'll see if I can give it a go myself too.
mygis
  • Sep 15, 2017 3:12 PM UTC
Hi Mark. It sounds great. I will give it a try and get back to you. Also please let us know when it runs on server as I want to try it out on fme cloud.
SOLVED.....
The beta works(Windows x86 for me), I just needed to upgrade the transformer and enter the Twitter account info an authenticate it again and now everything working again.
https://www.safe.com/support/support-resources/fme-downloads/beta/
@Mark2AtSafe Success!!! Thanks for the help. The transformer just needs updated and Twitter account re-entered.
mygis
  • Sep 27, 2017 2:17 AM UTC
Hi @Mark2AtSafe, are they any updates on the server side? Thanks
mark2atsafe
Hi @gisinnovationsb - yes, I believe the final commits went in last Friday. The build number that looks best to me is 17646. So far only build 17643 is on the web site. If you really needed it then that version should work (but there were a couple of minor bugs that got fixed in 17646, so it wouldn't be perfect). Let me know if you try it and have problems.
mygis
  • Sep 27, 2017 3:33 PM UTC
Thanks for the update @Mark2AtSafe , I wanted to give it a try on Cloud as well, but it is not urgent. I will start working with what I have.
mark2atsafe
News is that 17647 is the current candidate to be released next Tuesday. Just giving it a final look over to make sure is all good to go.
mygis
  • Sep 27, 2017 4:31 PM UTC
That's fantastic, thanks !
