trying to clip a shapefile using a polyline or polygon
clindsey
Forum|alt.badge.img+3
i am trying to clip a shapefile using a polyline and / or a polygon and the clipper keeps failing by saying that the "clipper outputs a rejected feature"
Forum|alt.badge.img+50
The Clipper feature needs to be one or more closed polygons, so a polyline won't work.
clindsey
  • June 18, 2019
when i look at the vertices in the shapefile it is closed. Is there something i'm missing?
aoi.zip
aoi.zip
It's closed indeed, but it's still a line. If you run it trough a GeometryCoercer, set to fme_polygon, before putting it through the Clipper it should work
clindsey
  • June 26, 2019
@redgeographics i just wanted to follow up and say thanks ... that had worked!
