Trying to apply a max number + row number into a new attribute field.
I have a dataset from a spreadsheet that i have created a counter for each row successfully.
imageThe SQL table i am importing this dataset into has a primary key (highlighted). This primary key is not recorded anywhere in the database as a sequence number.
imageI have added in a statisticsCaculator transformer to obtain the max number.
I want to insert each row from my dataset (first screenshot) but i want to insert the LUPID as count + LUPID.max. so i end up with 1691+1 = 1692, 1691+2 = 1693, 1691+3 = 1694 etc for each row
what transformer would i use to do this?
nielsgerrits
Forum|alt.badge.img+55
You can do this using an AttributeCreator or AttributeManager by using the value
@Evaluate(@Value(_count)+@Value(LUPID.max))
You can do this using the GUI by clicking the arrow in the Attribute Value field and choose "Open Arithmetic Editor..."
  • November 10, 2023
It sounds like you're trying to create a new attribute field in your dataset, where the values are derived from the sum of the maximum number in a specific column and the row number for each record. Here's a general guide on how you can achieve this using Python in a tool like pandas:
import pandas as pd
# Assuming you have a DataFrame named 'df' and a column named 'your_column'
# Replace 'your_column' with the actual column name in your dataset
# Calculate the maximum value in the specified column
max_value = df['your_column'].max()
# Create a new attribute field by summing the max value and the row number
df['new_attribute'] = max_value + df.index + 1
# If your dataset doesn't have a default index, you might need to reset it
# df.reset_index(drop=True, inplace=True)
# Display the updated DataFrame
print(df)
