Trying to all extract closed work order within a 45 day time frame.
  • May 3, 2023 2:46 PM UTC
  • 8 replies
  • 62 views
jamesb16
Having issues with info being extracted into the CLOSED 45 DAY attribute-that is created with the ATTRIBUTE CREATOR. Thanks for all recommendations.
dustin
Forum|alt.badge.img+36
  • May 3, 2023 3:05 PM UTC
If you are needing the date of 45 days prior to COMPDTTM, you can use the following:
@DateTimeAdd(@Value(COMPDTTM),-P45D)
jamesb16
  • May 3, 2023 4:29 PM UTC
In Attribute Creator, I add @DateTimeNow(@Value(COMPDTTM),-P45D) since I needed on todays date-45days from the COMPDDTM column. But none of the attributes are coming over to output CSV. Any suggestions
dustin
  • May 3, 2023 4:40 PM UTC
I'm not sure I fully understand. Do you want to filter the entries in the CSV that are within the 45 days prior to today's date?
jamesb16
  • May 3, 2023 4:46 PM UTC
Yes, I need all of the closed work order from todays date within the 45 days timeframe using COMPDTTM. Yes I do.
dustin
  • May 3, 2023 4:58 PM UTC
Instead of an AttributeCreator, use a TestFilter with this test condition. This will also take into consideration the Closed status, so you could remove the first TestFilter.
@DateTimeAdd(@DateTimeFormat(@DateTimeNow(),%Y%m%d),-P45D) <= @DateTimeFormat(@Value(COMPDTTM),%Y%m%d)
AND
@Value(COND) = CLOS
jamesb16
  • May 3, 2023 7:10 PM UTC
AND
@Value(COND) = CLOS
Any other suggestions, I did the modifications as listed previously. But wasn't able to run the model.
dustin
  • May 3, 2023 7:12 PM UTC
AND
@Value(COND) = CLOS
@jamesb16​ Ahh, my apologies. I had an error in my code. Correction is below.
AND
@Value(COND) = CLOS
jamesb16
  • May 3, 2023 7:45 PM UTC
Not a problem. Ran good with no errors, however all of the data were placed in <unfiltered> instead of <closed 45 days> . Any suggestion on what to look for, should I create a tester for just the CLOS (so it could filter those all those CLOS) prior to the TesterFilter and get rid of the AND clause that looks for the CLOS.
