Truncate table before insert
  • November 9, 2021
  • 320 views
coldon
I am trying to do an insert to CARTO table. It is mandatory to not drop the table because it is necessary anytime a table is created to make a specific SQL statement.
This table just has to have the last insert values so a truncate command is required.
I have tried with a SQL Executor with two statements. Truncate and Insert. What SQL Executor does is a truncate for every insert. At the end I have a table with only one row, the last value inserted.
Any ideas?
Best answer by nielsgerrits
You can use 2 SQLExecutors, one for one truncate and the other for the inserts. Using a Sampler and a FeatureHolder you should be able to run the truncate statement once and the insert statements after the truncate statement.
2021-11-09_15h24_43
As an alternative you could use an Aggregator to merge all insertrows in one feature, then add a truncaterow above it.
nielsgerrits
Forum|alt.badge.img+54
  • November 9, 2021
2021-11-09_15h24_43
coldon
  • November 10, 2021
Got it! Thank you!
