Trouble Reading AutoCAD Dynamic Blocks
Is there any way of reading AutoCAD dynamic block names/visibility states? Currently all I can seem to get is the anonymous '*U___' value in the 'autocad_block_name' field.
I feel like there should be a way of reading the real block name somewhere, as it picks up the correct block names in the reader parameters under 'Explode Selected Blocks'.
Any help would be appreciated!
Thanks.
danilo_fme
Forum|alt.badge.img+45
  • August 24, 2018
Hi @sammyc
There is a question similar, could you check if is the same: https://knowledge.safe.com/questions/67390/autocad-dynamic-block-name-extraction.html
Thanks,
Danilo
virtualcitymatt
Forum|alt.badge.img+36
Hi @sammyc - Looks like you're not alone on this one. Here's some more information: https://knowledge.safe.com/questions/3626/autocad-dynamic-block-name.html
Take note of the PR number referenced.
Also there is this idea here: https://knowledge.safe.com/content/idea/21982/writing-out-dynamic-blocks-to-autocad.html
virtualcitymatt
I've also created an Idea here which you can vote on: https://knowledge.safe.com/idea/77105/read-proper-dynamic-block-names-from-autocad-forma.html?
  • August 24, 2018
Just voted on it.
Would love to see this as a feature in the future. So many of the models I come across now use dynamic blocks.
