Trouble Deleting spatial rows in Informix
  • Jun 20, 2018 10:14 PM UTC
  • 75 views
Hello! I am getting errors while trying to delete records from using the Informix ODBC writers. I am putting the columns to match in the delete column row and getting an error that those columns do not exist:
IBM Informix Spatial Writer: Error - No column named ltt_id found in table xxxxx
Or just that there was error:
A fatal error has occurred. Check the logfile above for details... Last line repeated 2 times ...
and the only other thing written is a warning about assuming the geometry is 2D.
Has anyone else had any trouble with this?
debbiatsafe
Forum|alt.badge.img+24
Hi @colleenk_1
I would recommend checking the value of the parameter used to specify the table name in your writer. You could add it as an attribute to your features and use transformers to edit the value if necessary.
  • Jun 25, 2018 6:14 PM UTC
Hi @colleenk_1
job-6237.txt
Hi @DebbiAtSafe! I changed the names for the schema in the dynamic, and I had spaces after my commas in the delete key column line which gave me the above "not found in table error"
I am now getting that the job is successful and that a record was written to my table, but the delete doesn't actually happen, ie the record is still there when I look at the table in DBeaver.
debbiatsafe
job-6237.txt
Hi @colleenk_1
According to the Informix writer documentation, the infx_overwrite_table parameter should always be set to YES in the update and delete mode. Can you verify this writer parameter is set YES?
If you are still running into issues, please feel free to file a support case at https://www.safe.com/support/report-a-problem/
