Trim first characters with the BulkAttributeRenamer
  • Nov 10, 2022 1:59 PM UTC
  • 105 views
Hi all,
I would like to trim the first 7 characters from all the columns in my dataset. I think this can be accomplished with the BulkAttributeRenamer. But I'm struggling with the String Parameter. Any ideas? Bulkattributerenamer
  • Nov 10, 2022 2:04 PM UTC
You can try with this regular expression:image
nepalikiwi
Forum|alt.badge.img+4
  • Feb 8, 2026 10:53 PM UTC
Hi ​@david_r ,
I have similar issue, perhaps you can point in me right direction. I wanted to change my attribute name to camelCase, so using regular expression to find test following underscore using regular expression replace: _([a-z])
However, i am not sure what String parameter i have to put to make the selected character Capital letter. I have tried \U\1 and also few other but its not working. Basically wanting to find String parameter value?
  • Feb 9, 2026 8:17 AM UTC
Hi ​@nepalikiwi
Indeed, it seems FME does not support case modifiers like \L and \U here, even though they’re mentioned in the documentation for the regex library FME is using internally. You may want to contact Safe Support to verify this.
If you do not require using camelCase inside your workspace, you could consider using a PythonCaller to convert all attributes to camelCase just before the writer. Just be aware that the renamed attributes won’t be automatically visible (exposed) in your workspace, as would be the case with the BulkAttributeRenamer.
