Transposing multiple columns
  • Oct 10, 2019 7:01 AM UTC
  • 0 replies
  • 36 views
Hi All,
Thanks to all the experts for providing solution to my transposed doubt sometime back.
Here is an another challenge that i faced with now. I now have multiple columns instead of two.
where [A-R] are the required column names and the data from column 2 to last column should be the rows. Now i want two solutions:
1) Transpose only the given data in pic (must need)
2) The set of required columns (A-R) will repeat for the next file(when reading batch files) and needs to be given a common id and the entire data transposed. (optional)
Kindly help. Thanks
