Transpose dynamically (like the Excel command)
  • September 19, 2018
  • 13 views
peteralstorp
Forum|alt.badge.img+5
Hi. Me and my collegues have encountered this problem many times but we still haven't found an adequate solution. Please help! This is actually exactly what the Excel command Transpose does (when pasting copied data).
I want this data
to be transposed to this data
And if there a more ELEMENTS (after Zn) it should dynamically be included... We have looked at all the transpose posts here but we haven't found a good answer. ELEMENT, As, Ba and so on should be turned into attribute names for further use in the script.
Any help will be gratefully accepted.
Peter et al
Hi @peteralstorp,
If the following article does not help you: https://knowledge.safe.com/articles/1315/advanced-manipulation-of-excel-tables-using-attrib.html
I think the best option would be to explore the Custom transformer AttributeTransposer available on the FME Hub: https://hub.safe.com/transformers/attributetransposer
