Translation problem from GDB to DBase
  • Feb 14, 2023 4:07 AM UTC
  • 36 views
viviancfhung
I want convert a pure table GDB file(without geometry infomation) to DBase format.
It show me success and the result can be read by FME reader.
But It can't be read by any open source dbf reader included "dbf view of Microsoft" and "qgis".
I studied the document of .dbf from wiki and found that the schema definition of your dbase file is difference from document.
You use "I" for integer, But document is "N"
Is any way can I solve this problem?
Please check the definition of data type in document
imageThis is hex view of your .dbf fileimage
viviancfhung
  • Feb 14, 2023 4:34 AM UTC
I found the updated document. you are correct.
