Translation from dxf file to MapInfo creates only one layer, the last one even if it can see all of them.
  • Feb 23, 2021 5:46 PM UTC
  • 79 views
I have the new version. The old one used to do this very easily.
danilo_fme
Forum|alt.badge.img+58
  • Feb 23, 2021 8:00 PM UTC
Hi @rene_audet​
Is there some configuration in the Writer for fanout attributes?
Please, could you share our Workspace template? What version of FME are you using?
Thanks in Advance,
Danilo
darkspatiallord
Forum|alt.badge.img+8
do you have a single feature type foir the dxf? and how many writer feature types do you have?
  • Feb 23, 2021 10:19 PM UTC
I used to run the translator from within MapInfo and it was running all smoothly. I also could select to open non-empty layers only and specify line type, color, etc all from one small frame.
Now, what I get in FME Workbench is a bunch of yellowish arrow shaped objects - one for each layer, that I must run separately and eventually view in a window. The problem is probably that I am unfamiliar with this software that is very awkward for me to operate. So, frustration. I liked it much better when it was integrated to Mapinfo. Also, I am a self entrepreneur and can't afford to spend much money or time on software. I must make do with small resources and deliver my product - environmental maps for small lots. Thanks.
