Translation FAILED FME 2015
  • Jun 26, 2015 10:21 AM UTC
  • 0 replies
  • 31 views
hoa_le
Hi everybody,
I set up FME 2015 Desktop. When I transform format (tab to shp, dgn to tab...).
That's failed. But with FME 2014, I can do that normal.
Eror :
Expected an even number of command line arguments, instead got 85 for command line: >> `log' `file' `for' `DW WLAN Card.' `=====================================================' `Log' `Starts' `on' `Date:' `4-15-2015' `Time:' `15:06:46' `=====================================================' `15:06:46:' `GetOSInfo():' `Detected' `Windows' `7' `15:06:46:' `GetOSInfo():' `Product' `Type:' `Business' `15:06:46:' `PreInstallSetup():' `Using' `ini' `file:' `'C:\\Users\\HOALE~1\\AppData\\Local\\Temp\\{E6ADBC20-811A-4C88-B4BA-1DF976B6D8DD}\\{F16DD1B4-4933-4019-BC07-A9BF18830338}\\bcmwls.ini'' `15:06:46:' `Using' `inf' `file:' `'C:\\Users\\HOALE~1\\AppData\\Local\\Temp\\BcmWLSetup\\Drivers\\Win7\\WL\\bcmwl6.inf'' `15:06:46:' `Installation' `root:' `'C:\\Program' `Files\\Dell\\DW' `WLAN' `Card'' `15:06:46:' `Either' `the' `device' `is' `not' `present' `or' `the' `device' `is' `not' `supported.' `15:06:46:' `InstallShield' `script' `aborting.' `15:06:46:' `Entering' `function' `CreateEventLog()' `15:06:46:' `CreateEventLog():' `Failed' `to' `get' `Exit' `Code' `from' `registry.' `15:06:46:' `Exiting' `function' `CreateEventLog()' `=====================================================' `Log' `ends' `on' `Date:' `4-15-2015' `Time:' `15:06:46' `=====================================================' `LE\\AppData\\Local\\Temp\\fme_parameterFile.Ya7608' <<
Program Terminating
Could you tell me why? I've used Window 8.1.
Thank you
