transforming a folder to a file with odd extension.
  • May 16, 2022 8:33 PM UTC
  • 65 views
gboquin
Forum|alt.badge.img+8
I have a process were I need to create a downloadable zip file that contains a file that has an odd extension. So far I am able to create the folder, but the file copy writer is renaming the folder instead of making it a file with odd ext.
I have added a picture to show how the folder displaying how the folder got renamed instead of changing the extension and making it a file.
Thanks in advance for any feedback.
hkingsbury
Forum|alt.badge.img+73
  • May 16, 2022 10:20 PM UTC
The approach i'd take would be to first create a standard zip of the file (example --> example.zip) FME will be able to create that zip. Then, rename the zip to xyz (example.zip --> example.xyz) This could be done with python, system caller, or the filecopy
gboquin
  • May 18, 2022 12:24 PM UTC
Thanks @hkingsbury​  that was my fear. I need to play more with the settings for creating zip files as it was creating unnecessary folders-- basically a duplicate-- in the zipped file. Have a great day!
