Transformer XML-Templater Syntax
  • Nov 20, 2020 1:16 PM UTC
  • 30 views
Hello,
I have a little problem and I hope you can help me.
I use the transformer xmlTemplater. It works fine. But there is one problem:
If I insert an attribute with "<" or ">", the Transformer will change it in "lt&" or "gt&".
Is there any option, that the transfomer doesn't change the attribute?
  • Nov 20, 2020 1:39 PM UTC
That is by by design, as the XML specification does not allow you to use characters in your values that can lead to them being confused with XML tags.
See also e.g. https://www.w3resource.com/xml/reserved-markup-characters.php
