Transform local coordinate system using feature's bounding box center as origin
  • Mar 16, 2020 7:34 PM UTC
  • 100 views
alexlynch3450
Forum|alt.badge.img+16
Hello All,
I apologize if I am not making much sense, as I am new to 3d modeling.
I am having trouble trying to think of solution. I want to take spatial-vector data and output to local coordinate system. The local coordinate system, ideally, would be constraint to min and max extents of: -1m, -1m, 0.5m & 1m, 1m, 0.5m.
Right now, I am getting values larger than min and max extent when using localcoordinatesystemsetter X CommonLocalReprojector. I am not sure what I can do to equalize each x-, y-values in order to scale appropriately. Nor find transformer that I can input area-extent as min/max extent constraint. I am sure there is a mathematical formula, but am lost.
For example,
point-1_Local = -7.5403653628193155, -5.638463266998554, 0.5
point-1_LocalConstraint ~= -0.4817, -0.504, 0.5
point-2_Local = 7.502099056082192, 5.551721092860062, 0.5
point-2_LocalConstraint ~= 0.8439, 0.828, 0.5
jakemolnar
local_scale_example.fmw.zip
In case you want to have fine-grained control, here's a workspace that accumulates the 3D bounds of a dataset, moves features to the origin, scales each of the dimensions, and applies a final offset.
You could do this with a single 3DAffiner too, but this is easier to explain the steps.
This workspace is controlled by published parameters with defaults set to your specifications:
X_SCALE: 2 (the distance between -1 and 1)
Y_SCALE: 2 (the distance between -1 and 1)
Z_SCALE: 0 (the distance between 0.5 and 0.5)
X_OFFSET: 0 (features centered on x=0)
Y_OFFSET: 0 (features centered on y=0)
Z_OFFSET: 0.5 (features centered on z=0.5)
alexlynch3450
  • Mar 17, 2020 6:54 PM UTC
YOU NAILED IT! Thank you very much!
