transform dxf to gltf
  • Sep 12, 2023 1:05 AM UTC
  • 87 views
want to know detail process convering dxf to gltf
saraatsafe
Forum|alt.badge.img+13
  • Sep 12, 2023 11:09 PM UTC
Hi @minjoo​, to start, you can use the Autodesk AutoCAD DWG/DXF Reader to read in your data, and the glTF (GL Transmission Format) Writer to write it out again in glTF. Is there any data manipulation you'd like to do in between?
