Transform 2D-infrastructure-network in 3D
  • Dec 11, 2018 11:20 PM UTC
  • 5 replies
  • 103 views
Hi, I need help …..
I have an infrastructure-network with points and lines/polylines in 2D
and I want to transform it in 3D.
For the points I used the transformer „3DForcer“,
to assign them „Z_value“ to the z-coordinate,
there is no problem.
But to transform the lines (add the Z_value),
I don’t know how ?
Thanks for Your help …..
danilo_fme
Forum|alt.badge.img+58
  • Dec 12, 2018 12:08 AM UTC
Hi @chrst
I opened your Workspace and some changes was did.
The transformer PointOnLineOverlayer was used to do the spatial relation between the points and lines, because is necessary to pass the value Z from Points to Lines:
After I used again the transformer 3DForcer for Lines geometry.
Attached the Workspace template ( FMWT ) -points-lines-2dto3d.fmwt
Danke,
Danilo
  • Dec 12, 2018 9:36 AM UTC
Hi Danilo,
thanks for Your answer.
Now the single lines of the originally polylines have same z_value.
However, the start and end points of the lines should have the z-values of the corresponding points.
See attached file.
Thanks for Your help.
Christoph
01_Doc.pdf
  • Dec 12, 2018 1:53 PM UTC
If the requirement was to transfer z-value from a point to corresponding vertex of the lines, this workflow might help you. points-lines-2dto3d-2.fmwt (FME 2018.1.0.3)
  • Dec 12, 2018 9:41 PM UTC
Hi Takashi and Danilo,
thanks for Your help.
It was very very valuable.
If it were possible, I would like to invite you as a thank for a drink.
Wish you a good time of Christmas.
Christoph
danilo_fme
  • Dec 12, 2018 11:19 PM UTC
Christoph
Hi @chrst
You are wellcome. Sure! Drink some something.
Good Christmas too
