Transferring list of input files from one workspace to another ?
  • November 26, 2013
  • 8 replies
  • 77 views
I have the task of setting up a flexible transformation, first in workbench, later on an FME Server.
The input is a list of file paths from a view in an Oracle database, and based on a "category number" for each file, the relevant files of a given category should be converted by one out of multiple distinct workspaces. I.e. a 1-n "master-slaves" setup.
Note that the "features" in the "master" workspace is non-geom records from a alphanumeric view. I.e. not the features that need to be processed in the "slave" workspaces.
I have the master workspace setup, reading the Oracle list, splitting the output based on the category number, collecting the path names into a list, concatenating this into a semicolon separated text, and transferring this concatenated text as a single feature/attribute to a workspacerunner. I'm applying the separated text parameter to the source parameter of the input dataset in the called "slave" workspace.
But when I run the "master" workspace, it looks like the "slave" workspaces aren't run. And no output is produced by them.
I'm obviously doing something wrong, and I fear the I'm utilizing a couple of wrong assumptions. So here are a couple of basic questions to start with:
- Will the WorkspaceRunner run once for each submitted feature (non-geom) ?
- Will the WorkspaceRunner transfer texts to source input path lists in the called workspace, and will they be recognized as input specs in the called workspace ?
- How should a path name list be separated and escaped to work ?
Cheers.
  • November 26, 2013
The files to be converted as DGN files, by the way.
  • November 26, 2013
the WorkspaceRunner will indeed be called once for every feature that enters.
If your master workspace have a list of files to process you will have to convert it to a string before passing it on to the child workspace's published parameter. The format is usually
"filename"<space>"filename"<space>"filename"...etc
You do not need to escape the paths as long as you have double quotation marks around each item, like above.
Just be aware that if you have a very large number of files to process, the resulting string may be too long to pass as a published parameter. If that is the case, consider saving the list of files to a temporary text file and then passing that filename to the next workspace.
To debug this functionality consult the log files, they are indespensable.
David
  • November 26, 2013
I just re-visited an example from April 2008 by Mark Ireland ("Polygon Building"). It shows a parameter with a value of "&path_windows".
Is this a hidden string concatenator, and is this still relevant and the way to do it in a 2013 version ?
Besides, it uses a "PATH reader" which I cannot find in 2013.
  • November 26, 2013
Thanks David,
Is "<space>" a valid value for the separator ?
  • November 26, 2013
you must replace <space> with a proper space character.
The reader in question is surely the "Directory and File Pathnames" Reader.
I do not know what the "&path_window" is.
David
  • November 26, 2013
Hello David,
I have this specific portion of my processing located inside a embedded/custom transformer, and wanted the path separator as a published argument. This unfortunately doesn't work with a space character, so I had to revert to hardcoding it. That does work.
I found that one obstruction I was facing was the licensing. Each workspace requires a separate license, and I was running on a floating license, which then didn't allow me to start the other workspace.
As I was going to upload it to a FME Server eventually, I did that, and changed my WorkspaceRunner til a JobSubmitter. Unfortunately the job exits with an error, which I haven't had a chance to investigate, but at least it looks like the arguments are getting transferred correctly :-)
The total request string is almost 17k long, and the longest path argument is almost 5000 characters long. Is either of these a problem ?
Thanks for your help.
  • November 26, 2013
I don't know the hard limits when using the JobSubmitter, but in general terms I find 17K quite a lot.
You'll either have to experiment (e.g. by trying with just one or two file paths) or ask Safe support if you need a concrete answer, I think.
David
  • November 28, 2013
Thanks David,
I've submitted a support ticket about the possible limitations and explanation of the error.
Quite strange error response too: resultSucces=false but serviceSucces=true.
