Transfer python dictionnary between 2 Transformers
In a PythonCreator, I create a dictionnary. I'd like to use it in the following Transformer, a PythonCaller as an attribute.
So In the Creator, I finish with "return myDict". In the Caller, I call the attribute myDict.
But when I run the project, in the log, it tells me that :
TypeError: 'NoneType' object is not iterable
Do you have any suggestions?
Thanks
Best answer by david_r
Try this instead:
import json
import fmeobjects
class FeatureCreator(object):
    def __init__(self):
        pass
    def close(self):
        feature = fmeobjects.FMEFeature()
        myDict = {'Commune' : 'Tokyo'}
        feature.setAttribute('my_json', json.dumps(myDict))
        self.pyoutput(feature)
Notice how self.pyoutput(feature) always comes last.
Also notice that you have to import the json module.
If you attach a Logger after this PythonCreator you should get:
Feature Type: `Logger_LOGGED'
Attribute(string): `fme_feature_type' has value `PythonCreator'
Attribute(string): `my_json' has value `{"Commune""Tokyo"}'
Geometry Type: Unknown (0)
Hope this helps.
  • June 29, 2016
You can either define your dictionary as a global variable:
global my_dict
my_dict = {1'a'2'b'3'c'}
Then in a different Python transformer you can access it like this:
global my_dict
my_value = my_dict[1]
Alternatively you can pass the dictionary as JSON strings from one transformer to another using the feature attributes.
To convert a dictionary "my_dict" to JSON and store it in the attribute "my_json":
feature.setAttribute('my_json', json.dumps(my_dict))
Then later on you can read the attribute "my_json" and convert it back to a dictionary:
my_dict = json.loads(feature.getAttribute('my_json))
  • June 29, 2016
Thanks. But, I have a error in my log saying that the dictionnary isn't a string.
I checked printing the type of it. In the Creator, it is a string. But in the Caller, it became a NonType.
global myDict
def __init__(self):
pass
def close(self):
print json.dumps(myDict)
print type(json.dumps(myDict))
Is that because I'm doing it in a method in a class?
  • June 29, 2016
global my_dict
global my_dict
By the way, I'm new on this forum. Do I have to answer in the comment or in a new answer?
  • June 29, 2016
global my_dict
global my_dict
I also added my_json in the Attributes to Expose. Is that right?
  • June 29, 2016
That's correct!
  • June 29, 2016
You do as you feel :-)
  • June 29, 2016
Try this instead:
import json
import fmeobjects
    def __init__(self):
        pass
    def close(self):
Hope this helps.
  • June 29, 2016
global myDict
def __init__(self):
pass
def close(self):
Hi @slerendu, found two issues.
  • A global variable should be declared in the method definition that refers to the variable. In this case, you have to declare the 'myDict' global variable in the 'close' method.
  • The feature should be output AFTER assigning a value to the global variable. If the feature was output BEFORE assigning a value to the variable, its instance haven't been created yet when the feature arrived to the next PythonCaller.
  • June 29, 2016
global myDict
def __init__(self):
pass
def close(self):
In addition, if you save the dictionary into a feature attribute as a JSON document, it's not necessary to use a global variable. See @david_r's answer.
  • June 29, 2016
david_r wrote:
Try this instead:
import json
import fmeobjects
    def __init__(self):
        pass
    def close(self):
Hope this helps.
Perfect. Thanks a lot.
Someone at my place told me that I can create my dictionnary in a startup python script. Is that a correct use? I find the json method cleaner.
What do you think?
  • June 29, 2016
What do you think?
Apples and oranges.
If the dictionary stays the same during the entire translation, I'd just make it a global variable or something like that. You can create a global variable wherever you want, basically, including in a startup script.
If the dictionary is feature specific, I'd go the JSON route.
  • June 29, 2016
david_r wrote:
Apples and oranges.
Thanks, it's clearer now.
  • June 29, 2016
Thanks for your answer. My problem was indeed the feature output.
  • June 29, 2016
When you say global variable, you mean "global myDict" in the PythonCreator or in the startupPythonScript?
  • June 29, 2016
I thought that you needed to define the global variable in the PythonCreator since I found the declaration within your script. However global variables can be defined anywhere according to your requirement. All depends on what you want to do with scripting ;)
  • June 29, 2016
Ok, thanks :-)
