traffic data analysis
  • Feb 17, 2022 10:04 AM UTC
  • 67 views
dallas2011
Hi everyone, I have a question about my thesis.
I have a point layer witch including data about the traffic(speed, cars number ect..). And I have a road layer. I don’t know how to connect the the point layer to the line as the closest segment of the line get the datas from the closest pont…
Thanks in advance
  • Feb 17, 2022 10:23 AM UTC
dallas2011
  • Feb 17, 2022 10:41 AM UTC
thank you the answer, just one question. I have ShP database about a capital city, and i have point dates, which are include the speed data. And i am looking for a solution for, i set de distance and only the neighbor line get the datas,this time all line database gets data but a need to reduce for example 5m radius circle and if the line there get it if no, wont get it. Thank you in advance for your help
danminneyatsaf
Forum|alt.badge.img+13
Hi @dallas2011​ the Bufferer would allow you to create a 5m radius circle around your points. You could then use a SpatialFilter to check which lines intersect each circle and attach the attributes of the intersecting feature.
Hope this helps!
dallas2011
  • Feb 21, 2022 3:01 PM UTC
Thank you, i could make it.
