Topologybuilder: z values are not considered while computing intersections.
  • Jan 24, 2024 11:47 AM UTC
  • 57 views
geouser97
Hello, i used the topologybuilder transformer to build the topology of a network ( roads centrlines).
The problem is that z values are not considered while computing intersections. So it may not produce correct results for overpasses, inderpasses....
Any recommandations please. Thank you.
geomancer
Forum|alt.badge.img+71
  • Jan 24, 2024 1:55 PM UTC
Which is as the documentation states: "Though Z values (elevations) will be retained on features, they are not considered when computing intersections."
So you should find a way to exclude the overpasses, underpasses... (maybe by some attribute? maybe by it's Z-values? maybe something else?)
geouser97
  • Jan 24, 2024 3:04 PM UTC
if I exclude them before the transformer, it is not possible since the transformer will create a node each time there is an intersection, if I exclude them after it will destroy the topology created since the identifier of the node and the edge has already been considered in relations with other entities.
