To map month in number to month in alphabets For Example) mapping 01/01/2018 to 01/jan/2018
  • Jan 9, 2018 3:21 PM UTC
  • 78 views
Best answer by erik_jan
This can be done using the DateFormatter transformer, using these settings:
erik_jan
Forum|alt.badge.img+26
  • Jan 9, 2018 3:54 PM UTC
gio
Forum|alt.badge.img+15
  • Jan 9, 2018 4:53 PM UTC
the help shows U the format strings
fmelizard
Forum|alt.badge.img+22
  • Jan 9, 2018 7:03 PM UTC
If you are working with FME 2017.1 or above then it will be the DateTimeConverter (will look like below). Note the 'quick guide' section. Also if you want to learn more about the Date/Time stuff you can read this section of the Doc: https://docs.safe.com/fme/2017.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/dateformatter.htm
  • Jan 10, 2018 5:02 AM UTC
Thanks for your solution.
