TM to UTM conversion
kathir
Hi, actually i have the data worked in tm that was converted into utm. i have created the projection https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Create_Form.fmw using this link.but i dont know how to assign coordinate system for my projection.i need to idea about how to create projection and how to import the coordinate system for the corresponding projection. here i had attached my prj file. i have my dat abased on this projection.i need to convert into utm.
pratap
Forum|alt.badge.img+11
  • July 15, 2019
Which reprojection transformer are you using?
kathir
  • July 15, 2019
reprojector and attribute reprojector transformers are used
kathir
  • July 15, 2019
hi actually i need detail about custom coordinate system. i can create projection and don't know how to set coordinate system for that projection
pratap
  • July 15, 2019
You can refer in FME installation folder with folder name "Reproject". Add your custom projection in "MyCoordSysDefs.fme" file... I hope instructions are provided in the below link...
custom projection link
Note: Make sure you keep backup of this file before adding new projection content...
kathir
  • July 15, 2019
hi,thanks for the reply.shall you send the screenshot any example
kathir
  • July 15, 2019
here attached the file created by me. import and reproject the data but that was error. not corrected output
pratap
  • July 15, 2019
Sample format of projection is explained in My*.fme file such that you have to maintain in same syntax and proceed further... It cannot be explained here with short notes. so, read the link provided and proceed.
Other option is, if you have FME with Esri Edition then use ESRI Reprojector. Save the projection as prj file and select the prj file, while assigning the reprojection...
Pratap
kathir
  • July 16, 2019
pratap wrote:
Pratap
h, i was tried esri reprojector also, but i dont get correct final output. that is my problem
kathir
  • February 12, 2020
pratap wrote:
Pratap
Hi i need sample .fme file for TM Projection(That contains False east,False north,Origin of Lat,Central medirian values) and also need sample for HOB(Oblique mercator projection)based on False east,false north,lat of orgin ,central meridain, azimuth angle.
