TIN Generator runtime error R6025
  • Mar 23, 2017 2:27 PM UTC
  • 7 replies
  • 93 views
I´m trying to import mash (OBJ) to Oracle Spatial as a TIN by using TINGenerator transformer. I´ve got a Microsoft Visual C++ Runtime Library error:
Does anyone have an ide what can I change (setting, input, output?) to reach my goal? :-)
Thanks!
/Lenka
itay
Forum|alt.badge.img+19
  • Mar 23, 2017 3:01 PM UTC
Sounds like a support case to me.....http://www.safe.com/support/
  • Mar 23, 2017 3:53 PM UTC
Could be a problem with your input geometries. Perhaps try a GeometryValidator first.
  • Mar 23, 2017 7:09 PM UTC
OK, I´ll give a try, thanks!
  • Mar 24, 2017 6:42 AM UTC
GeometryValidator didn´t find any problem but I´ve got stil the same error - "R6025"....maybe I should really contact support, what do you t
hink?
itay
  • Mar 24, 2017 6:57 AM UTC
hink?
I would....
  • Mar 24, 2017 7:30 AM UTC
Hi @lreinwart, a possible reason is that "fme.exe" (FME engine) has been broken with any reason. I think it's worth to try re-installing FME.
  • Mar 24, 2017 7:40 AM UTC
I agree, I've seen very similar messages when there's a problem or conflict with the run-time libraries. Some pointers here: https://knowledge.safe.com/articles/417/errors-due-to-missing-microsoft-visual-c-redistrib.html
