Timezone
Hello, I have an Timestamp attribute in UTC time (e.g. 20180311013252.000). I would like to create a new attribute converting the UTC Timestamp to EST/EDT Time. After that both attributes should be transformed to %Y%m%d. In this example the output should be 20180311 for UTC and 20180310 for EDT/EST.
Best answer by takashi
Hi @kat, if you are using FME 2017.1+, you can use the @TimeZoneSet function to convert timezone of a datetime value. e.g.
@TimeZoneSet(@Value(_utc_datetime)+00:00,-04:00)
You can then format the datetime values with the DateTimeConverter transformer.
The @DateTimeFormat function can also be used instead of the DateTimeConverter transformer.
@DateTimeFormat(@TimeZoneSet(@Value(_utc_datetime)+00:00,-04:00),%Y%m%d)
See also here to learn more about FME Date/Time functions.
  • May 2, 2018
danilo_fme
Forum|alt.badge.img+45
  • May 3, 2018
Great solution and tutorial :)
  • May 3, 2018
Wow, that's great! Thanks a lot.
Does it consider daylight saving time (-5 in winter and -4 in summer) or it must be changed manually?
  • May 3, 2018
If the timezone setting of your machine was EST/EDT, this expression would automatically determine the local time.
@TimeZoneSet(@Value(_utc_datetime)+00:00,local)
Otherwise, you will have to implement a process to switch the timezone (-04:00 or -05:00) according to the input date.
  • July 31, 2019
Is there a way to automatically take into account DST without "local"? I'm creating a model that will run on a server in one time zone but will need to be able to convert the time to PST/PDT automatically.
