Timeline for ETL workbench to support Esri Communications Data Management model, part of Esri Utility Netowrk?
  • Dec 16, 2020 3:20 PM UTC
  • 48 views
We are needing to migrate fiber data from a typical GIS-based fiber platform into the new Esri Communications Data Management model (uses Esri Utility Network), however, the data structures are completely different when it comes to associations for items like fiber strands and equipment ports.
@kgally16​  I think FME would support the Esri Communications Data Management model now using the Esri ArcGIS Portal Feature Services reader & writer.
For the migration, that would be via the Telecoms Asset package. I'm not sure if that has been released yet (Dec 2020). We have developed migration workspaces for Gas, Water & Electric and these are available here. You could probably use the ideas in the gas or water migration workspace as a template for the telecom migration workspace.
