Time consuming between FME 2023 and FME 2022
  • Sep 18, 2023 12:54 PM UTC
  • 57 views
pratap
Forum|alt.badge.img+12
I have prepared workbenches using FME 2022. Few days back, I have installed FME 2023 build 23603 FME 64bit. When I executed the workbench in latest version then translation is very slow when compared. I have crosschecked one again by running same workbench in FME 2022 and translation has completed as previously.
Whether any other have encountered same issue??
itsmatt
Forum|alt.badge.img+48
  • Sep 18, 2023 6:32 PM UTC
FME is pretty big with a lot of components etc - with each release Safe Software like to claim that it gets faster and faster. If there is a slow down somewhere it might be pretty specific to one of the transformers or formats you're working with.
If there is a slow down they might want to know - If the data are easy to share then you can support a support ticket to them and attach the workspace and data.
